rims and tires
Old Jan 21, 2016 | 5:50 AM
Jeffrey Oliveri's Avatar
Default rims and tires
Have 15 x 8 rims with 235 75 15 tires
Want to go bigger on rims and tires anyone know how big I can go with out any rubbing issues 2002 express 1500
Old Jan 21, 2016 | 12:34 PM
hightechredneck1956's Avatar
you are missing information....What is the stock wheel back spacing?
Old Jan 21, 2016 | 12:49 PM
suppose your new wheel has exactly the same backspacing as your old wheel...and you stick with 8" wide...then your tires are 28.9" tall...you can easily get a 30" tire under there so you could run 245/70/16 or 255/65/17
The thing to remember is that you need a Light-Truck Tire (10plys)....if you don't run a truck tire you'll be lucky to get 25000 miles on them...
I run Cooper Discoverer LT265-70-16 on American Racing Rims....I like the look and they are fairly quiet to run.
The backspacing on my 2016 was 4.75"
Old Jan 21, 2016 | 2:07 PM
canucklehead's Avatar
Also check the tires size calculator on 1010tires.com. You need to stay close to the outer circumference of your stock size.
Old Jan 21, 2016 | 2:34 PM
which was 28.9"
Old Jan 21, 2016 | 5:35 PM
here is a great chart.....
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
put the stock tire on the left and play around with the right side
