Roadmaster Steering Stabilizers
Old July 21st, 2020, 9:54 PM
SteveROntario's Avatar
Default Roadmaster Steering Stabilizers
Has anybody tried these things? They make two flavours.
There is one for vans with cross members under the engines (RBK17) and one for without (RBK15).
https://www.roadmasterinc.com/pdfinst/RBK15.pdf
https://www.roadmasterinc.com/pdfinst/RBK17.pdf
https://www.roadmasterinc.com/pdfinst/RSSC.pdf
The reviews seem favourable for dealing with front end wobble.
Old July 22nd, 2020, 1:22 PM
vehicles shouldn't wobble. I would fix it , rather that look for things to bolt on.
Old July 30th, 2020, 11:08 AM
ray caldwell's Avatar
I agree with Joe. Rotate wheels and if it still has a wobble . Check air in all tires and treadwear. Alignment can be checked with string in garage to see if it's off. Toe in/camber problem.
Because I was in Houston with all their lovely roads.... I do have a stabilizer I got off
a jeep and went on easily with a hole in crossmember and a clamp. I also run off-road rancho shocks on the front.
Was not for a wobble. My van stays in a straight line when I hit a rough patch.
Old July 30th, 2020, 4:01 PM
Lakeman 903's Avatar
I have one, not sure which now, but I was changing out the front springs, AirLift 5000 Air Bags for the Rear, and Bilstein’s all around, so I went ahead and switched out the OEM Stabilizer. This is the 3500 Express and converted to a a Roadtrek Campervan...the intent was to raise it About 3”. When it was done, a good wheel alignment was the final thing. It hands great....even the wife wants to drive. I like that heavy Spring in the Roadmaster.
Old July 30th, 2020, 4:29 PM
OEM stabilizer? You mean the anti-roll bar.
The OP is talking about steering stabilizers. Different thing.
Jay44 (February 20th, 2021)
Old July 30th, 2020, 10:42 PM
I say OEM because it was on there when I bought it new....nothing more than a fifth shock. It sure wasn’t a roll bar.
Old July 31st, 2020, 2:11 AM
I have never seen GM put a steering stabilizer in a van.
Old July 31st, 2020, 9:24 AM
You may not have seen the, bit this is the second 3500 I have had, the first an ‘05 and this ‘15, both with the 6.0 engine. Both were bought brand new as Roadtrek Campervans.
Old July 31st, 2020, 12:25 PM
So Roadtrek put them on. Roadtrek is not the Original Equipment Manufacturer.
Old July 31st, 2020, 7:51 PM
My van has had an alignment and is in spec, the only thing that may be a problem is the rag joint and pitman arm area. If you wiggle the steering wheel quickly you can get something in that area to clank similar to when it goes into a wobble. Is it possible that less than adequate front shocks could cause this? I did a bunch of work to the van recently and that included changing the shocks to what I feel are not stiff enough.
I would be curious to see what the "newer" Roadtreks came with. Mine is 2004 Popular 190 and it did not have one.
Quick Reply: Roadmaster Steering Stabilizers
