Rubber Floor liner
Rubber Floor liner
When I first bought my van I concluded the rubber floor liner had to go. My thinking was if I sheet the floor in plywood I can screw mounts and stops to the floor so certain items will sit in predefined spaces without moving. Also, plywood should allow sheets and such to slide easier. I didn't seem to believe the rubber floor mat/liner would last over time. Has anyone's ripped? Do they last after having things dragged across them over and over? It seems thin.
If I put a plywood floor in, I was planning on using stainless steel self drilling screws, screwing the plywood right to the steel floor, but I wonder about rust. Naturally the screws be exposed underneath the van. Think this would be a potential for rust down the road? I'm just looking for opinions, ideas, corrections.
Thanks.
Thanks.
Just put plywood over the rubber to protect it. You will want to keep the insulation that is under the rubber. 2 layers of 3/8th with staggered seams......you could screw it together with 5/8th screws.
Charlie5280
March 20th, 2014 11:33 AM
T-bone
July 26th, 2011 11:54 AM
