Sliding Door Power Lock not working 2006 Chevy Express 3500 V8 6.0 Gas passenger van
![Question](https://chevroletforum.com/forum/images/icons/icon5.gif)
The power door lock on the sliding door of my 2006 Chevy Express 3500 V8 6.0 Gas Passenger Van no longer works. The front doors power locks work ok.
Need to determine how to diagnose this problem: Fuses, relays, actuator, door connections (two contacts), etc.
Official GM Rep
LeeHamilton, are you looking to repair the vehicle yourself or would you be willing to have a dealer take a look at the vehicle? Thank you for your time.
Jeff Morris, Chevrolet Customer Service
so the question has compounded to how to replace door handle (hopefully from junkyard) and diagnose solenoid.
Door handle should be easy enough to see once you get the panel off.
My slider has a little issue where the plastic button that slides up and down to lock and unlock get kinda stuck on the way up, so when i cycle the lock to lock the van the slider tries to lock, but doesnt. I find that if I press on the door panel it frees it up.
I did some flexing and got it to work. but I have to double check once in a while.
goyakpacking
May 9th, 2015 7:51 PM
karabug27
Uplander
November 16th, 2011 7:56 PM
