Express 3500 Sliding door handle repalcement
Old Jun 14, 2012 | 4:26 PM
jstchilln's Avatar
Default Express 3500 Sliding door handle repalcement
The sliding door will not open on our 2006 Express 3500 van while using the outside handle. The door will open from the inside. . I want to remove the inside molding and see if there is anything wrong with the handle or replace the handle. How is the inside molding attached ? Any tips?
Old Oct 30, 2013 | 12:39 PM
goodolboy7's Avatar
This is an easy fix. mine was just an adjustment. remove clip from the inside handle and remove the handle. there are two clips holding the small panel at the handle. once removed you will see the rod coming from the rear of the door. it runs into a clip - undo clip and adjust the rod forward. Check adjustment by reaching around the rear of door and activating rear lock with your fingers. once it is in the lock position try door handle and see if it unlocks. repeat until properly adjusted.
Old Sep 3, 2020 | 2:18 PM
Pepi LeTourneau's Avatar
Default Rod handle
I wish I knew how to quit you...😂
phness
Avalanche
11
Sep 4, 2022 9:36 PM
jampg
Jan 3, 2017 11:03 AM
ts8181
Jan 17, 2015 3:58 PM
jadmiral
Astro
Jan 6, 2013 8:29 PM
Franklin71
Dec 30, 2010 8:40 PM
