Sliding Van Door
Old Aug 25, 2021 | 4:33 PM
generationhexed's Avatar
Default Sliding Van Door
hey all,
I have a 2004 chevy express 3500 with a manual sliding door. It got in an accident at one point and has been unable to open since. Recently, it seems as though something else got loose and the door is violently shaking when I go over 60mph. I want to go to the pick and pull to get a new sliding door. Im wondering if anyone has any helpful tips/tricks to removing the sliding door and possible installing the barn doors instead. I imagine the track to the sliding door is warped which is why it won't open. Trying to figure out what to do, I haven't had much luck online. Thank you to all in advance
Old Aug 29, 2021 | 2:09 AM
William Kisselstein's Avatar
On this generation of vans the hinges are welded in place. The barn door has a different step well than the slider. I don't think it has any provision to mount the latches, the small door latches top and bottom and the larger door latches to it. It would require a large amount of fabricating, or changing over parts, to make the swap work.
Probably the handle is broken or bent, this is very common. The van I had with a slider, sometimes it required pressing in the sheetmetal with your hand behind the outside handle for it to unlatch.
Which, if it's shaking, it's probably not latched correctly.
Old Aug 30, 2021 | 9:25 PM
tsoleno's Avatar
Me, I would start@ the inside door handle and remove the trim, then the panel to see what it takes to release. I've broken that handle on mine. Maybe have someone tug the rear of the door outward as the handle is activated.
johnnythunder
Aug 3, 2019 6:47 PM
BostonInfidel
2014 - 2018 (GMT-K2)
Mar 31, 2019 11:12 PM
captainkip
Jan 19, 2016 6:43 PM
ts8181
Jan 17, 2015 3:58 PM
Dumowery
10
Aug 22, 2014 12:26 AM
