smog
Old May 4, 2015 | 12:37 AM
chignola's Avatar
Default smog
i have a 1977 g20 van. it doesn't require a catylitic converter (as by the emission label) .it also has a air injection pump.i failed the calif. smog test because my NITROUS OXIDE readings were 3333 ppm @ 15 mph & 2611 ppm @ 25 mph. what can cause these readings ?
Old May 4, 2015 | 8:01 AM
high combustion temps cause nox to form. the egr system is designed to lower the temps by introducing exhaust gases back into the fuel charge. Inspect the egr system to see if the valve is opening and the passages are not blocked.
jayjiggums
K5 Blazer
Aug 17, 2008 12:25 PM
kato
Nov 30, 2006 7:30 PM
k101979
Jul 20, 2006 5:42 AM
