Smog check
I took my RV in for a smog and the guy hooked up a (scan tool with bidirectional controls), and lo and behold, I have a check engine light I didn't have before. Is it possible for someone to use a bidirectional scan tool to for example, set your purge valve open or change other settings to cause the check engine light to come on and give you P0171 & P0174 codes? Seems to me the only thing that should have been hooked up to my OBDII port was the smog test machine
Top
