Tail lights
Tail lights
I have a 1999 Express 3500, extended 15 seater. I'm having a lot of trouble with the tail lights. Bulbs are all fine. Signals flash too fast, when the brakes are applied ,all the lights go out except for the back-up lights, which come on. I check all the bulbs and they are fine when I put them back in. A couple days later more problems occur. This is driving me nuts. Is there a harness ground or something that could be bad? I'm not impressed with the type of socket being used for the bulbs, is there a newer replacement socket I can use?</P>
</P>
Thanks for any help.</P>
RE: Tail lights
i have an 01 and the dealer here had run a jumper ground wire for the brake bulb outside of the lens to a ground point. after i removed it i have intermittent problems like yours. so i am going to put the wire back. passenger side by the way
RE: Tail lights
ORIGINAL: vinster888
RE: Tail lights
I had the same problem and fixed it the same way. I am having problems with my back up lights. I have a 99 s-10 and the back up lights won't come on when I throw it in reverse. Any help?
Guest
Posts: n/a
RE: Tail lights
RE: Tail lights
The problem is caused by a poor ground wire connection. Where this is is the tough part. Easy cure is to add a ground wire (common wire to all lights) from the light cluster to the van body.
97 Tahoe "The Rig"
August 12th, 2014 9:45 PM
skdevore
August 26th, 2009 10:18 PM
