TCM pin inside transmission broke
Old Dec 8, 2017 | 7:17 PM
Yanksfan829's Avatar
Default TCM pin inside transmission broke
trying to get the plug into the TCM on the transmission, pin #2 (ground) broke. Anyone have recommendations to fix it rather than buying a new one? ^^^Top left pin
Old Dec 8, 2017 | 8:35 PM
Rednucleus's Avatar
is it broken off flush? Maybe drill it out and secure with a conductive epoxy. Seems to me I have heard of a "silver epoxy" maybe from Radio Shack??
Old Dec 8, 2017 | 8:48 PM
Unfortunately it is completely broken off. From the electrically diagram, PIN number 2 is ground (LMM or LGH any idea what that means?
Old Dec 9, 2017 | 1:18 AM
jimmydriver's Avatar
try to solder it back on.
Old Dec 9, 2017 | 11:41 AM
Artie1's Avatar
LMM is a 2008-2010, and the LGH is a 2011-2016 Duramax Diesel engines.
L20 and L96 are 4.8 and 6.0 gasoline engines.
Seems like your vehicle doesn't even use that Pin 2. Easiest way to verify is to look on the vehicle side of the connector to see if there's a wire coming in.
