Transmission Cooler
#21
Thanks Joe for the explanation. I have a blue Driver scanner, I don't know if it will read tranny temps. This is more of a homeowner device, but it does read, "live" data in some areas like long and short term trim.
I can always cut into the return line to install a, "T".
#22
Scan-Gauge II might be able to do it, you will likely have to find the "X-guage" code and program it in...I had to do that on my old FMC motorhome that I swapped a duramax/allison in..
#23
Unfortunately, only emissions data (OBD Mode 1) has been legislated to be live to owners. Everything else has to be, sort of, hacked.
It doesn't look like Blue Driver has any expansion or programming features so I think you're out of luck with that.
But their website advertises it as "Professional Scan Tool" in big letters!
Then you're just measuring your cooled down fluid. It doesn't really tell your what's going on inside the transmission, so not very helpful.
I wouldn't worry too much about it though. The additional cooler will make a big difference. Unless you're fighting forest fires, your transmission will be very happy.
#24
If you want a dedicated sender then drop the pan (good time for new filter) drill a hole and use a bulkhead fitting https://www.ebay.com/itm/Moroso-2263...seY:rk:19:pf:0 , you may want to consider adding a pan with a drain at the same time...Dorman makes a deep pan with drain for the 700r4/4l60e for less than $50
#25
#26
The reviews on Amazon suggest that it doesn't.
#28
Well, then he could get a cheapy ELM Scanner on eBay, or get the one I prefer https://www.ebay.com/itm/ELM327-Blue.../302475561957? Get the Torque Pro app ($5), and an inexpensive tablet, and have a nice display.
#29
Ah ok. This is the first I've heard of it working on our vans. It didn't work on my 2013. Did you just use the gauge included in the app? Do you know if your van uses VPW or CAN protocol? It seems that 2008 was a transition year.
#30
Hi, what didn't work on our vans, the Torque app, or the trans temp? Yes, the gauge is from Torque Pro. I don't know the protocol, or what that means.
