Transmission fluid change & flush torque converter
Old Aug 22, 2013 | 12:04 PM
Vandeejim's Avatar
Default Transmission fluid change & flush torque converter
89' G20 101,000 miles
Fluid looks amber/clear I think its time to drain it?
Will I be able to draw the fluid from the dip stick tube, then run engine to drain torque converter or will I have to drop the trans pan then run engine to the drain torque converter?
Thanks for all your help,
Jim
Old Aug 22, 2013 | 7:24 PM
canucklehead's Avatar
It is 120 bucks to have a tranny shop to change your fluid and filter. Might as well just get them to do it. I would not just change the fluid only.
Old Aug 23, 2013 | 8:44 AM
Vandeejim's Avatar
Why doing it myself? Here in NJ, PepBoys and 10minute oil change charge 150 dollars and NO pan drop and NO new filter. They draw the T-fluid out from filler tube while engine running to drain some T-fluid from torque converter.
Years ago I watched 10minute change mine for 75 dollars, they had to brace up trans and then remove the cross-member mount of transmission to remove pan. They did not run the engine to loosen some T-fluid from torque converter?
All suggestion are welcome, thank much.
Jim
Old Aug 23, 2013 | 8:50 PM
spaceblonde's Avatar
I would talk to a true transmission shop. Big difference from a jiffy lube or Pep boys !!
Old Aug 23, 2013 | 11:45 PM
My thoughts exactly. Phone around. I bet a tranny shop is better and cheaper.
JoeBlow
11
Apr 27, 2012 11:08 AM
jgray152
Jul 12, 2010 8:22 PM
DeHartShadow
Mar 28, 2010 10:10 PM
