Transmissions. Older 4 speed towing capacity
Old May 21, 2025 | 12:21 PM
MattinMi's Avatar
Default Transmissions. Older 4 speed towing capacity
Looking to purchase an Express van. I see in the specs, the older 3500 van with a 4 speed has a 14000 combination two rating. The newer 6 and 8 speeds have a 16000lb. But the old 4 seems to be a pretty reliable transmission. Do you think GM was being soft on the gross combination rating? Or should I really look for the newer transmission? Towing a 6700lb dry camper. It's listed as a 28' but OA length is about 34'.
Old May 21, 2025 | 3:25 PM
Triaged's Avatar
4l80e is a nice transmission. 4l60e not so much.
Old May 25, 2025 | 8:38 AM
Derrick71's Avatar
I don't get the question. Even at 14,000 pounds for the 4-speed you're still way under the capacity with your camper. I believe you have to go with 2010 or newer to get the 6-speed in the 2500 or 3500.
the Brain
Jun 25, 2023 5:44 PM
greenfire
Oct 22, 2022 9:11 PM
cjm1973
51
Sep 2, 2021 2:01 PM
0621katt
Jun 20, 2021 4:50 PM
dperreault
Jul 26, 2014 10:44 AM
