Turn signal Wiper arm Removal
Brand new member as of about two minutes ago! I need some help from the experts please!
I broke the multifunction switch (wipers/turn signals) arm. The arm snapped off inside the switch housing. I found a replacement but can't get the old one out and the new one in.
I can't find any information from the usual sources (YouTube, etc) so I'm here for expert advice. How the heck do you remove the broken off silver nub to replace the arm?
Good luck. Ok it's been too many years since I've been that deep into a steering column and I don't remember how the blinker arm comes out. At least you don't have a tilt column!
Please make sure you provide your vehicle details, like model year. Thanks.
I was stuck on the way the switch mounted to the base plate. Turns out the posts that looked solid was actually a pin. You could tap it out the backside and that released the switch.
Rob
Weller41
1988 - 1998 (GMT400)
December 31st, 2019 12:36 PM
