U0121 Crank, no start
Old Jul 28, 2022 | 9:45 PM
Casper2020's Avatar
Default U0121 Crank, no start
I've got a 2012 chevy express 3500 that currently is crank but no start with code U0121 (TCM lost communication with brake control module). It has been having intermittent issues where it would flash 'service traction control' and the ABS light would come on while driving, but then would immediately go away and no other symptoms. Today it did the same thing but this time the van lurched forward before the issue went away and 100 feet later (at 5mph in a parking lot) the van completely turned off and would not start again. Why would an ABS code cause the van not to start? Apparently the 12V 'wake up' wire for the ABS module is split with the fuel pump which maybe explains explain the lurch and why it won't start.? Any thoughts on this?
Old Jul 29, 2022 | 12:54 AM
make sure modules have power, ground, and CAN signal. If they do, and still can't communicate then its failed.
Happened to my TCM. $700 to replace and reprogram.
Bravo GM.
Old Jul 29, 2022 | 10:01 AM
Triaged's Avatar
https://m.youtube.com/watch?v=qVCklDoXbHAGive that a watch. Look for some bad wiring.
Old Feb 16, 2025 | 7:40 AM
Luis-Angel's Avatar
Default 2013 Chevy Express 3500 crank no start
Hello, I was so wondering if I could get some help. The same thing is happening with my Chevy Express 3500. Have you ever found a problem with your Chevy?
QUOTE=Casper2020;480997]I've got a 2012 Chevy Express 3500 that is currently cranked but has no start with code U0121 (TCM lost communication with brake control module). It has been having intermittent issues where it would flash 'service traction control' and the ABS light would come on while driving, but then would immediately go away and no other symptoms. Today it did the same thing but this time the van lurched forward before the issue went away and 100 feet later (at 5mph in a parking lot) the van completely turned off and would not start again. Why would an ABS code cause the van not to start? Apparently the 12V 'wake up' wire for the ABS module is split with the fuel pump which maybe explains explain the lurch and why it won't start.? Any thoughts on this?
[/QUOTE]
Chevyawka
Aug 19, 2024 4:46 PM
2001 chevy silverado
Nov 18, 2021 9:21 AM
Austin Schwarz
May 17, 2021 7:02 AM
NewfoundlandBurban
Mar 20, 2020 3:03 PM
JoeC
Jan 12, 2020 10:10 AM
