Unsettling noise
Old Aug 20, 2023 | 5:29 PM
cmac2012's Avatar
Default Unsettling noise
A couple of weeks ago I noticed a sort of loud sputtering. That’s what it sounded like in the cab anyway. I checked everything, oil was in the lower range, I added more, the next day the noise was gone.
It keeps coming back, usually after a long-ish freeway trip. Last night when I got home, I took this video/audio:
This morning I went for a short drive, when I got home I took another recording:
Intermittent problems drive me crazy. I don’t trust it when a problem heals itself. Odo reads 186K approx. When the noise is really happening, I start imagining shopping for a long block or a new truck.
My stethoscope is down at my storage. I’ll give it a good listen next time I’m down there, I’ll see if I can find where it’s coming from.
Old Aug 20, 2023 | 6:24 PM
Triaged's Avatar
I'd start with looking for an exhaust manifold leak from a broken bolt as that's a common problem. That does sound bad and could be a rod knock but hard to pinpoint the noise from video. No forbidden glitter on the dip stick? If it's not an exhaust leak I drain the oil and cut open the filter. Stethoscope or piece of hose would be best to find the location. All the other fluids look good?
Old Aug 21, 2023 | 12:30 AM
cmac2012's Avatar
That is wonderful to hear, the possibility that it might be an exhaust manifold bolt. Certainly not proven yet. It’s interesting though, because about two months ago, I had some time on my hands, visiting my sister in Washington state. She had a big open garage, I had the wild idea to maybe get the heads done and at least get new intake manifold and valve cover gaskets. It became clear I didn’t have the tooling or the time to do the heads but I did the rest. However, I took the exhaust manifolds off first in preparation, and had to put them back on of course. The bolts were old, I reused them.
OMG, what a happy day that would be, if that was whence the noise cometh. I hadn’t heard of that before, but it makes sense. Every exhaust stroke, t’would fart out hard, into that loose manifold, loose at that point, and give a quick bang.
I need to stay on earth until I know for certain though. The fluids all look really good. And the way it sounds so nice in the morning - it seems like the rod would just keep knocking. As to why it would heal up, temporarily, who knows. I’ll get that stethoscope tomorrow and get busy. I would sure like to get another year or two or three out of this thing before the long block is undertaken.
dwebst02
May 11, 2023 12:04 AM
CherieApparentlyMustLearn
Nov 29, 2021 11:03 AM
ohlookitsnate
Nov 15, 2019 11:51 PM
kalvinc10
Avalanche
Apr 2, 2017 10:08 AM
TimC2520
Dec 29, 2015 2:26 PM
