Upgrade Express to 4 wheel drive?
Old Nov 12, 2024 | 9:45 PM
okrobie's Avatar
Default Upgrade Express to 4 wheel drive?
I'm planning to purchase a 2008 3500 Express and it's in excellent condition with only 166K miles. An excellent fit for my needs, but I was hoping to find one with 4X4.
Assuming that I can find a front axel and a transfer case in a local U-pull junkyard, would it be a good idea? Would it be a practical project for a DIY'er with reasonably good skills? I really don't need it, but I'll be upgrading from a 2002 1500 Suburban which has 4X4 and I like not getting stuck on muddy roads etc. It has saved my butt on numerous occasions.
So what do y'all think? Am I sounding foolish?
BTW, how do I find out if it has positraction or limited slip differential. The seller hasn't a clue.
Thanks, Jim
Old Nov 12, 2024 | 9:54 PM
Triaged's Avatar
Look for G80 on the RPO code sticker. If it's there you have a Gov-Lock.
So you're looking at a solid front axle swap?
Old Nov 12, 2024 | 10:05 PM
okrobie's Avatar
I'm not planning to swap out of the Suburban, if that's what you mean. I didn't think it would work, but would it be possible? The Suburban is a 1500 and the Express is a 3500.
If it's feasable, It sure would save me a lot of slogging around in the U-pull yards. Not tha I haven't done my share of that.
Old Nov 12, 2024 | 10:23 PM
Triaged's Avatar
https://weldtecdesigns.com/product/w...er-suspension/
Not cheap. You could fab yourself a solid axle swap out of a Ford F350 if you are good at fabrication but will likely end up with a lift too.
Old Nov 12, 2024 | 10:50 PM
okrobie's Avatar
That might be out of the budget and more than my skills will allow. If it's practical, I think I could do a chevy swap if the parts will match up.
Do you think swapping the axel and transfer case out of the Suburban would work?
Old Nov 13, 2024 | 9:32 AM
jfmorris's Avatar
My understanding is that the entire front suspension is different for 4WD versus 2WD. Think upper/lower control arms, and all the other stuff that ties to the front wheels.
Old Nov 16, 2024 | 5:22 AM
okrobie's Avatar
Thanks for the information. I determined that it does have Gov-lock and I really don't need 4X4 so I bought the truck.
Crzzydog56
Jul 15, 2024 3:42 PM
cray54
23
Mar 19, 2021 2:51 PM
Aolson6
12
Feb 16, 2021 11:20 PM
mich7thm
Feb 2, 2018 7:46 PM
2008express
Sep 28, 2011 5:00 PM
