Wacky Ignition troubles 06 Express
Old May 5th, 2015, 11:11 AM
CNG Pete's Avatar
Default Wacky Ignition troubles 06 Express
I was given this vehicle to work on because it ran like crap.
Initially I found damaged and broken wires. They were repaired.
Suspecting poor connections on the CNG conversion (done by another shop) I opened up the harness and made sure it was all soldered correctly.
I also secured the main harness away from the #1 coil that it was laying on top of.
Final work was new plugs and wires.
Van ran great, and the driver was impressed how well it was running.
Add a week, and its running crappy again. Driver complained of backfires too. My test drive confirmed it didnt run as well as when I gave it back, and further the driving deteriorated where it barely ran but I got it back to the parking spot.
Is there anything common to fail on these with a heat soak?
Next is getting codes. They will give a clue, but last time it was multiple codes that really didnt make sense.
After this, next job is fixing the ABS properly.
-Pete
Old May 9th, 2015, 6:49 PM
mp2140's Avatar
That sounds interesting. I've never had a CNG system on a vehicle. It irritates me when mechanics don't do their job right. I've repaired a lot of wires because mechanics are either too lazy or too ignorant to cover up and secure wires. You'll have to let us know what you find out.
Old May 9th, 2015, 9:33 PM
Rednucleus's Avatar
Is it a system that you can switch back and forth between gasoline? Run equally bad on both fuels?
Old May 21st, 2015, 12:48 PM
CNG Pete's Avatar
BUMP! Back to the top.
Havent had time to look at this until today.
Didnt take long to find the problem, but will take MORE time to find the source.
Even bank lost its spark. I had previously repaired damaged wiring on that side and thought the repair was done. I guess not. Wiggling the wires restored the spark. Now to find out just where the bad connections are. It appears that ALL coils drop out when it has the problem. Time to dig up the wiring diagram.
-P
Old May 21st, 2015, 1:52 PM
CNG Pete's Avatar
Found it! Pink wire on the connector to the coil pack.
Already repaired two other wires, so I think its time for a pigtail.
-P
Acoustic Pete
Avalanche
July 1st, 2014 6:24 PM
a-ron
November 11th, 2011 8:13 PM
NUSNS
December 15th, 2010 11:36 AM
pearlgirl
October 26th, 2008 10:29 AM
thdrill
October 26th, 2007 10:32 AM
Quick Reply: Wacky Ignition troubles 06 Express
