Washer fluid problems
Old Mar 2, 2024 | 3:51 PM
Jade M's Avatar
Default Washer fluid problems
Hey y’all!
My washer fluid won’t spray and I’m having problems trouble shooting. There’s fluid in the res, I replaced the water pump, and the wipers themselves work perfectly. How should I go about potentially unclogging the lines or seeing if the problem is somewhere else? Thanks in advanced!
1984 Chevy g20 conversion van
Old Mar 2, 2024 | 9:07 PM
did the fluid freeze?
Old Mar 3, 2024 | 1:05 AM
Jade M's Avatar
Maybe back a month ago but it’s been 90 degrees this week.
Old Mar 3, 2024 | 1:18 AM
try activating the pump manually
Old Mar 3, 2024 | 2:16 AM
Derrick71's Avatar
Can you hear the pump running?
Old Mar 3, 2024 | 12:47 PM
if you don't hear the pump...have someone activate the washers...unplug the electrical connector at the pump...one wire should have battery voltage...the other should show ground.
Oldirongut
Colorado
Jan 3, 2022 11:42 AM
Inari
Dec 18, 2018 11:11 AM
papawali
Jan 3, 2013 6:16 AM
in2pro
Nov 7, 2010 5:38 PM
johnboy
Dec 3, 2007 7:52 PM
