washer reservoir
Old Jan 13, 2014 | 7:12 PM
littlebear60's Avatar
Default washer reservoir
I have a 2001 express 2500 with a 5.7L. Need to replace the washer pump but can't seem to remove the reservoir. Does anyone have any ideas?? I remove the bolt at the top front of the tank and the tank will swing out but won't pull up. It seems like it should be easy to remove but the best laid plans.......HELP!!
Old Jan 13, 2014 | 7:44 PM
tsbrewers's Avatar
See if this helps, you need to remove the hose and the electrical connector after you tilt it out.
File Type: pdf
91boz
Jan 4, 2023 12:46 PM
JLewis59
Avalanche
May 25, 2010 2:06 PM
johnboy
Dec 3, 2007 7:52 PM
damaarh
Sep 6, 2006 2:13 PM
