Welded nut for gas tank strap... naturally it broke loose. Solution?
Old May 17, 2017 | 2:56 PM
lunghd's Avatar
Default Welded nut for gas tank strap... naturally it broke loose. Solution?
Hello again. Another curse-laden adventure with this thing.
Need to replace fuel pump sender... so new pump while I'm at it.
Problem: The rear captive / welded nut for the rear fuel tank strap (inside frame crossmember) broke loose and now spins merrily around with maybe 1/8" or so of thread left (based on comparison to front bolt).
I have the tool bins & rubber mat flooring... which is secured on both sides BENEATH the tool bins.
I'm thinking to drill pilot holes from beneath & then use a hole saw to open up above that loose weld nut. Anyone know a better way to do this before I put a hole-saw on the drill and imagine Mr. Goodwrench's skull underneath as I open up the floor?
(I am not going to remove the tool bins just to flip the rubber back... but I also don't want to destroy the matting as it's crucial for sliding materials in & out without damage. If I didn't have the rubber matting I would have just cut a hole in the floorboard & replaced the pump that way.)
Old May 17, 2017 | 4:36 PM
kevinkpk's Avatar
Can you stick a flat blade screw driver on one side to hold it while you unscrew it?
Old May 18, 2017 | 4:45 AM
lunghd's Avatar
Good idea and actually tried that but not enough room for leverage against the small amount of nut visible.
It wasn't actually a welded nut but one of those stupid 'clip on' 'blind-nuts'... a nut with a sheet metal clip that lets you slip it into a blind hole and the clip holds it in place for assembly when you can't get a wrench to the back side. It was made to speed things up on the assembly line... but not being strong enough for disassembly was the problem.
I ended up taking a reciprocal saw & just cutting the bolt off. I got very, very, VERY lucky to have a similar clip-on nut from an old Ford I had in the 90's (yeah - I have buckets of crap...) Not the same design but also had a bolt with matching threads that was long enough. After that - it was pretty much like any other job where you needed a lift but have to make do in the driveway. Didn't totally disconnect the tank - just dropped the back end down to the ground & supported the front so that there was still slack in any hoses etc.
I'm sure the neighbor kids learned a whole new set of adjectives for school tomorrow...
Thanks for the response.
Old May 25, 2017 | 3:28 PM
lunghd's Avatar
Found the actual replacement parts if you bust that damned captive nut & have to cut the bolt off like I did. It's a Dorman part & can be found at most local auto parts in their "HELP!" parts area.
Dorman Help Fuel Tank Strap Hardware Kit #55157
It's this set : http://amzn.to/2qkOSzF
