What is this called?
Old May 17th, 2012, 1:44 PM
Er Au's Avatar
Default What is this called?
Hey my issue is one of my fuel lines under the injector housing were the large bolt screws in leaks, the bolt keeps turning like it's stripped but then some parts around it (I am guessing it's Cast Iron) with a bit of the threading broke off. Here are some pictures to help with what I am referring too
On the top of the fuel line there, that is were the cast iron came from, the metal that shattered off was white on the inside. I know this means I need to replace it, but I have no idea what it's called.
Old May 17th, 2012, 1:48 PM
Er Au's Avatar
Oh sorry, my van is 1993 Chevrolet G20
Old May 17th, 2012, 2:07 PM
Er Au's Avatar
here is the piece that broke off
Old May 18th, 2012, 7:38 PM
RacerX's Avatar
you have to put an arrow on what you are referring to.
Old May 19th, 2012, 4:20 PM
Er Au's Avatar
Old May 20th, 2012, 12:43 PM
neo71665's Avatar
Throttle body injector pod. Its cast aluminum and easily stripped if over tightened. That steel part should have seals on the end and doesn't require bottoming the threads all the way to seal. Sounds like somebody tried to tighten it to seal a leak instead of replacing the seals resulting it being stripped.
Good news is that injector pod is the exact same for 2.8, 4.3, 5.0, 5.7, and 454 engines. You just gotta use the regulator and injectors out of the screwed up part.
Old May 20th, 2012, 1:34 PM
RacerX's Avatar
are you sure? because the tiny pieces in post #3 look like they came off the throttle body housing. I think to be sure you may have to remove the throttle body and look at it from the underside and see it the metal is torn.
Old May 21st, 2012, 4:17 PM
Former Sponsor
johntaps's Avatar
The throttle body is discontinued from GM and Delco. We can get this for you if you call us 888-282-5545. You are looking in the neighborhood of $600.00.
This retailed over 1600.00 from the dealer when they were available.
Old May 21st, 2012, 4:32 PM
RacerX's Avatar
what year and model is your car? and where do you live?
Old May 22nd, 2012, 10:38 AM
Er Au's Avatar
there ya go, I live north of Jackson, MS
Quick Reply: What is this called?
