What does the chime sensor look like for a 2008
Old Jun 30, 2022 | 10:27 AM
Fabulus333's Avatar
Default What does the chime sensor look like for a 2008
Trying to locate the chime sensor for 2008 Express 3500. Started chiming while driving. It's constant on some days then once for twice the next. Use it for transporting workers and the chiming is hair raising. Can't find the reason for it so just going to unplug it until I figure out the darn thing. Thanks in advance for your input.
Old Jun 30, 2022 | 10:19 PM
There's no such thing as a chime sensor. Nobody needs to sense a chime.
You need to find out what is causing the vehicle to chime. Either it thinks the door is open (which would be a door latch switch), or it thinks a seatbelt is unbuckled (which would be a seat belt switch), etc.
Usually there is a warning light on the instrument panel telling you the reason.
Old Jul 1, 2022 | 5:05 PM
Fabulus333's Avatar
Default My bad I meant to say chime module.
I actually meant chime module which is located somewhere under the steering column. The cause is supposed to be an abs issue. We've checked everything with the brakes including the wiring. One weird thing is that when it's raining it doesn't make any noise. I just don't want to unplug the wrong thing. Thanks for your input.
Old Jul 2, 2022 | 12:03 AM
Triaged's Avatar
I don't know what year it started but at least as of 2015 the chime and blinker noise is played through the driver's door speaker.
Old Jul 3, 2022 | 12:01 AM
Then maybe you should fix your brakes.
Old Aug 1, 2022 | 5:26 PM
Edward Andriaccio's Avatar
the chime module is usually located behind the radio below it
Old Aug 1, 2022 | 5:28 PM
if its comming on because of the brakes,,,your vehicle might be equipped with the pressure safety switch for the brakes ,the connector is located below the brake master cylinder
justjeff1862
Feb 1, 2022 3:23 AM
Wesley Garibay
2007 - 2013 (GMT900)
Feb 6, 2017 11:15 PM
eddychevy
Dec 7, 2012 1:39 PM
Ziggie
Jun 17, 2012 2:10 PM
2008express
Sep 28, 2011 5:00 PM
