what vehicle did these wheel come off seller doesn't know proballey ran off w/it. I think this could be a GM made rim.
will it fit the 05 chevy express 3500 8 lug?
will my rear door tire carrier have a hub type holder or just a couple studs holding rim? like I'd rather test fit rim on the carrier. I don't have a floor jack w/ me (I'm still away from home). when it warms up I'll remove the spare cover.
my spare is dry rotted where the sun beams on it inbetween door & carrier, the cracks are no thicker than a hair. I'm planning new rims then purchase only 4 Michelins.
I was thinking it mite be a good idea to stuff this spare into a black hefty bag (or maybe canvas) to cover the exposed part of tire to prevent or slow down the dry rot process.
edit: the tires that are on the van are LT245/75/16 the spare is a full sized tire. this new spare I'm wanting is a tad wider at LT265/75/16 what are the chances new tire is to wide to fit inside carriers cover?
I just google search the image it appears to be a ford f250 rim thanks for advice
I thought this rim was GM. google thinks it's a ford.not sure if there interchangable
I've been informed that the vans require a certain offset. these orginal wheels sure appear small on the back.
I was planning to get new aluiminum rims on this white van I believe they are made by american racing.
the white van upper left 05 pleasure way lexor td - Google Search
Don't guess. I've learned from that mistake (got stranded in the bush)
I test fit the wheel right on my vehicle in front of the seller. And it has already saved my ***.
