what vehicle did these wheel come off
Old Dec 26, 2022 | 10:07 AM
the Brain's Avatar
Default what vehicle did these wheel come off
what vehicle did these wheel come off seller doesn't know proballey ran off w/it.
I think this could be a GM made rim.
will it fit the 05 chevy express 3500 8 lug?
will my rear door tire carrier have a hub type holder or just a couple studs holding rim? like I'd rather test fit rim on the carrier. I don't have a floor jack w/ me (I'm still away from home). when it warms up I'll remove the spare cover.
my spare is dry rotted where the sun beams on it inbetween door & carrier, the cracks are no thicker than a hair. I'm planning new rims then purchase only 4 Michelins.
I was thinking it mite be a good idea to stuff this spare into a black hefty bag (or maybe canvas) to cover the exposed part of tire to prevent or slow down the dry rot process.
edit: the tires that are on the van are LT245/75/16 the spare is a full sized tire.
this new spare I'm wanting is a tad wider at LT265/75/16 what are the chances new tire is to wide to fit inside carriers cover?
I just google search the image it appears to be a ford f250 rim
thanks for advice
Old Dec 26, 2022 | 11:27 AM
Well if he really wants to sell them, then he'll measure the bolt pattern for you. But they don't like any factory GM wheels I've ever seen.
Old Dec 27, 2022 | 9:51 AM
the Brain's Avatar
I thought this rim was GM. google thinks it's a ford.not sure if there interchangable
I've been informed that the vans require a certain offset. these orginal wheels sure appear small on the back.
I was planning to get new aluiminum rims on this white van I believe they are made by american racing.
the white van upper left
05 pleasure way lexor td - Google Search
the van tire size is LT245/75/16 e rating 116 or higher.
there's another seller w/ aluiminum H3 hummer rims however these tires are wider LT285/75/17 and taller.
what are the chances of these rims fitting the van?BF Goodrich LT285/75 R 17 & Rims - auto wheels & tires - by owner -... (craigslist.org)
thanks
Old Dec 27, 2022 | 4:29 PM
Don't guess. I've learned from that mistake (got stranded in the bush)
I test fit the wheel right on my vehicle in front of the seller. And it has already saved my ***.
myinhousebigdog
Oct 27, 2024 10:39 PM
dupontcarpet
Feb 14, 2022 11:15 PM
