What's the difference between fuses IGN A vs IGN B?
Old Aug 16, 2021 | 9:46 PM
B9M8's Avatar
Exclamation What's the difference between fuses IGN A vs IGN B?
The fuses are numbered 49 for IGN A and 52 for IGN B, both 40 amps. Does anyone know what they are and their difference?
Interested in the back story? Long story short, my father's 07 Express 1500 randomly stopped working - It cranks but doesn't start (happened in driveway).
He has changed: fuel pump, body control module (under passenger side airbag), ignition coil, crank shaft sensor, distributor cap and rotor, ignition sensor module and it still didn't start.
After replacing these parts, he removed the alarm system the previous owner had installed, didn't help. Next he checked the fuses, all intact and functioning. After this, he took a spare fuse (thinking someone might have messed with his van) and placed it into slot 52 IGN B, the van started up perfectly! The car continues to function with a fuse in 52 IGN B (don't worry, no one is moving the van with this fuse in slot 52 IGN B).
Neither one of us are mechanics and I've hit a dead end - I don't know how to help him. Towing and/or dealership service is unfortunately not possible. Does anyone have any idea of what's going on to his van and what IGN A / IGN B are and why placing a fuse in IGN B worked?
Thank you so much in advance!
Old Aug 21, 2021 | 9:34 PM
DwayneInBC's Avatar
Hi.. Owning a express 1500 myself with its own issues, I can understand what he's going through. I can tell you that with mine, there should be a fuse on the ign-b slot. I can't remember if it's a 40 or 50 amp needed. Best advice I can give you, is to check under the fuse box cover, there it should tell you the proper size. I fear that someone may have been screwing with you and just pulled that fuse, or put it back on the wrong spot.
I can quote tell you the differences between the two, though GH I can tell you both are needed for the ban to run properly.
He's good to go with the fuse in. Hoped this helped, even just a bit
DwayneInBC
17
Jul 15, 2021 6:59 PM
Glenn Cole
Nov 21, 2019 11:27 AM
Gfarm
Aug 25, 2017 9:02 AM
v8mananiamniam
Sep 22, 2012 8:57 AM
johnram1500
Jul 2, 2012 7:41 PM
