Wheel exchange for 2001 3500 Express
I have a 2001 Express 3500 cut away or cab&chassis, which has the 8 lug OE steel wheels, single rear wheels not duallys, There is a set of 8 lug OE aluminum wheels on a 03 2500 Chevy pickup. I have checked if they will fit but not comfortable they will be safe weight-wise, mine is near GVWR. I have lo
oked on the net but not sure if I have checked every place I can. Does anyone know if they are interchangeable or know a good site to check? TIA jIm
Rockauto lists wheel dimensions and bolt pattern so check on there.
aluminum is lighter than steel and I don't think a pound or two is going to affect yoru GVWR significantly.
Keep in mind that if you hit a curb or big hole, aluminum shatters, unlike steel. So it could make the difference between driving away from a mishap or not.
jjrbus (February 7th, 2022)
I see guys in the demo derbies running what look like aluminum wheels when they can find them.
I suppose when they get old they could crack, but 8 lug suspension is usually rated for 9600 lbs even if the truck is badged 2500.
jjrbus (February 8th, 2022)
I've seen people put these on vans.
https://midwestwheelandtire.com/prod...lloy-wheel-rim
Those wheels are forged not cast so they bend not crack. They are strong wheels but getting older and harder to find a nice set at the wrecking yard.
Not knowing anything about wheels has me concerned about swapping OE wheels out for something fancy, so I have ben poking around net and found this, hopefuly will help someone.
tron-van
May 22nd, 2021 7:31 PM
Roger1
September 24th, 2018 12:14 PM
Doug_Dornbos
April 3rd, 2013 2:19 PM
