Wheel info - 2010 Express 3500
Old Sep 28, 2010 | 5:15 PM
Tonawanda's Avatar
Default Wheel info - 2010 Express 3500
For those considering a wheel upgrade to their 2010 Express 3500, here are some critical measurements:
Wheel diameter: 16"
Wheel width: 6.5"
Offset: 25mm (~ 1")
Backspacing: 4 7/8"
Bolt pattern: 8 x 165mm
Wheel tuck in front: ~7/8"
Wheel tuck in rear: ~ 1/2"
The front knuckle/hub-carrier on the 3500 has very little clearance at the top of the wheel - about 1/2". Realistically, any replacement wheel can not have more than 5 1/8" backspacing. On the outboard side, the wheel can grow about 7/8", before it breaks the plane of the body line at the center of the fender.
My requirements were to maintain load capacity at the wheel and tire, and to not have tires sticking out of the fenders. In the end, I was able to find *one* wheel that worked: Eagle Alloys 058, in a 16 x 7 width. The wheel has a load rating of 3040lbs, and an offset of +8mm.
I looked at the ATX wheels and others - I just couldn't find a wider wheel that would correctly package under both the front and rear of the van.
Just thought I would post this, to save others a bit of time.
-Bruce
Old Aug 28, 2011 | 11:46 PM
glull's Avatar
Default How did this work out?
How did this wheel fitment work out?
Old Aug 29, 2011 | 12:15 AM
Tonawanda's Avatar
Perfectly. The wheel dimensions are about the limit for my requirements (wheels/tires remain tucked under fenders)
Best,
-Bruce
goyakpacking
37
Jan 27, 2024 2:01 PM
MRaymond1
May 21, 2022 9:41 AM
goyakpacking
Jun 29, 2015 4:54 PM
goyakpacking
May 9, 2015 7:51 PM
jair143
Sonic (Aveo)
Mar 3, 2011 5:31 AM
