Where can I find an ABS module
Old Mar 8, 2023 | 6:52 PM
Proline1988's Avatar
Default Where can I find an ABS module
Hi everyone. I could use some guidance. I have a 2010 Chevy Express 1500 hitop conversion van. 5.3L with rear wheel drive. After changing many brake related parts I still a traction control light on. Codes won't clear. Turns out a I an ABS module. Chevy has discontinued them, and noone in my area has one, not even used. Problem is my van has stabilitrack(Active braking control) I need a certain one with the code JL4. Don't know anyone around me that rebuilds them. Don't know what to do. Can anyone help me with my problem please? Otherwise I'm driving around with no abs and a light on.
Old Mar 8, 2023 | 9:01 PM
hanky's Avatar
There are times when a part is used for a few years as models are released.
Did you check with one or two dealership parts departments ? They would be able to tell you which years use the same Hydraulic control unit.
Old Mar 13, 2023 | 1:04 PM
Default Abs module.
Thankyou Hank for replying to my thread. I've called several dealerships and have received the same answer from all of them. Not in stock and discontinued. Tried several rebuilders of modules and no luck there. Trying to find used parts that fit.
Old Mar 13, 2023 | 9:00 PM
Triaged's Avatar
You can try LKQ for a corporate dismantler. For other places a lot of them use car-part.com for inventory. You might check for other parts on a recent wreck and call to see if they have the module you need. Have you tried Cardone for rebuild?
Old Mar 14, 2023 | 6:57 AM
Default Abs module
I haven't called Cardone directly, but checked their website: no good. Also checked Lkq: no good there either. Have a friend in Canada who's checking for me
Chevyawka
Aug 19, 2024 4:46 PM
kmdakota1
Oct 6, 2022 5:35 PM
PastorK
Feb 27, 2010 12:57 PM
Irishlad
Apr 20, 2007 10:36 AM
bisben2
Nov 9, 2006 7:43 PM
