Where is the horn on my 3500?
Old Jan 12, 2015 | 10:47 AM
Mikesbaron's Avatar
Default Where is the horn on my 3500?
My horn is not working on a van I just purchased, even after replacing the relay and checking to make sure all the fuses are good.
I want to check the actual horn itself but I could not find it peering around the engine bay. Can someone tell me where it’s located on my van?
Old Jan 12, 2015 | 12:21 PM
solwav's Avatar
Behind drivers headlight, 2003 cargo van.
Old Jan 12, 2015 | 1:05 PM
Mikesbaron's Avatar
How easy was yours to remove? I'll have to check in that area again on mine. I looked there last night with a flashlight but didn't see anything.
Old Jan 12, 2015 | 8:30 PM
solwav's Avatar
My horn works so I did not look to see how it is mounted. I recall the horns location after changing the upper radiator hose, it is almost directly underneath.
Old Jan 12, 2015 | 9:49 PM
Mikesbaron's Avatar
Thanks, my 1999 horns are in the same spot, below driver's side headlight. One bolt and the bracket that holds them on is removed. I found that there was some corrosion (green crap) that was likely causing the issue. I've tried scraping the contacts with a small pick but I need something to clean it even better. Any ideas what I can use?
KM4363
Apr 18, 2017 6:55 AM
isaac_22
Dec 26, 2007 9:23 PM
zulu
Mar 28, 2007 4:58 AM
Mr.Twister
Nov 15, 2006 10:28 AM
mcarlson14
Jul 11, 2006 1:33 PM
