Where is the low beam relay in an express bus?
Old Nov 9, 2018 | 8:38 AM
Village Auto's Avatar
Newly Registered
Default Where is the low beam relay in an express bus?
We have a 2010 express bus at our shop. The headlights go on and off randomly. Fuses are fine, switch is fine, we are fairly certain we have a relay problem. We can not find this relay anywhere, the book doesn't show a relay, however the under the hood fuse box shows in a section labeled "Circuit board relay (not shown)" a low beam relay. Does anyone have experience with these and know where the relay is located?
Old Nov 9, 2018 | 10:41 AM
dberladyn's Avatar
Click on the link 'GM Upfitter' in my signature. Browse Light Trucks, Look for your Year, Select the Electrical Schematics link for your Van.
Old Nov 9, 2018 | 2:29 PM
PCB relays are non-replaceable (likely solid state devices), and your problem lies elsewhere. Check for loose connections, broken wires, bad switches etc.
Old Nov 10, 2018 | 9:41 AM
LCAC_Man's Avatar
forward lighting relays are in the UHFB...your problem sounds like a loose ground wire though...there are some just inside the drivers kick panel and then some on both the drivers front frame and drivers side of the engine block..
