Whistling when shifting gears
Howdy all! New member here.
I just purchased a 2002 Chevy Express 1500 LT factory conversion van. It has about 145k on it. But it's in really good shape apart from a few small scratches and normal wear and tear. It seems to run very well. However, sometimes I am getting a slight whistling sound when it changes gears. Like right before it kicks in fully to the next gear. It doesn't happen all the time but more often than not. Any ideas?
Thanks!
Thanks!
Sounds like when its between gears and there's no load on the drive shaft it makes noise, could be the driveshaft carrier bearing.. Can you replicate the condition? For example Neutral coasting? It would be ideal to jack it up and run it but this would be dangerous.
Thanks guys. Something I noticed - seems the whistling is happening less often now for some reason and doesn't seem to be associated with shifting gears after-all. It whistled briefly a few times when just cruising down the road. Seems I read somewhere that this whistling is somewhat common in some GM trucks. I'll keep you posted if I notice anything else unusual. Thanks again!
peerware
May 1, 2013 6:46 AM
rtarb41323
Sep 19, 2012 3:48 PM
