White smoke under acceleration on 95 G30
Old May 1, 2018 | 11:14 AM
number1tonner's Avatar
Newly Registered
Default White smoke under acceleration on 95 G30
I have smoke coming from tailpipe while turning and accelerating . I've been lucky to have owned this van since 170,000 miles on the odometer and we are at 345,000 now. She still has power but consumes a large amount of oil and vibrates like a bass drum at stoplights. The smoke has me concerned.
Any ideas?
Old May 1, 2018 | 2:45 PM
Using the power steering puts extra load on the motor.
Could it be steam? When's the last time the heads or intake were touched. I wouldn't be surprised if the gaskets were on their way out.
Old May 1, 2018 | 7:49 PM
canucklehead's Avatar
Coolant leaking. Head gaskets most likely.
Vibration could be from poor spark or from the extra combustion in the wet cylinders....
I would pick up a used engine.....but the swap is a big big job....vans suck for that.
Old May 1, 2018 | 8:52 PM
what engine?
if its the 6.5 diesel...white smoke can be caused by diesel fuel combustion as low temps.
if its a gasser...have a closer look at the colour of the fumes..bluish tint in the white cloud is oil burning in a tired old engine. have a look at the spark plugs for ash deposits on the center or side electrodes.
Old May 10, 2018 | 8:40 PM
Ragnar's axe's Avatar
kinda unrelated but @ around 100k my import was blowing a lot of white smoke during start up and maybe intermittently in-between... During a valve cover gasket replacement my mechanic found a build up of sludge in the breather chamber causing the issue...
