Forum Notice Stop in here to get the latest on CF happenings! This is also the place to get some information about site usage and the rules of the forum. Only staff and those permitted by the staff may post a new topic in this section. For permission to post something here, contact EvansBlue.
cleaned tps now i get 3k high ideal
Old Nov 25, 2018 | 8:43 PM
James West's Avatar
Question cleaned tps now i get 3k high ideal
I cleaned the tps and now I get a high ideal I deleted the codes with innova 3120 but now I get p0507 high air code im so lost and confused any help if I leave the breath tube off just resting next to it it ideals down plz im stuck 2 days now
Old Nov 26, 2018 | 12:22 AM
oilcanhenry's Avatar
PO507 is the IAC. Could be something else too.
A vacuum leak Leaking air intake after the throttle body EGR valve leaking vacuum A faulty positive crankcase ventilation (PCV) valve Damaged/failed/dirty throttle body Failed EVAP system Failed IAC (idle air controller) or faulty IAC circuit
