Forum Notice Stop in here to get the latest on CF happenings! This is also the place to get some information about site usage and the rules of the forum. Only staff and those permitted by the staff may post a new topic in this section. For permission to post something here, contact EvansBlue.
Ignition
Old Mar 26, 2017 | 6:39 PM
dewayne22's Avatar
Default Ignition
Ok, bone head mistake, long story short, 05 suburban 1500, installer spliced into a ignition wire off of remote start wire to power up another device under the center console. That wire was accidentally dropped and touched metal ( ground) while the truck was running, it made the truck shut off, and now you turn the key and get nothing, no dash at all , I changed the ignition switch and still nothing, anyone know of any fuse that I might have missed as now I'm stuck trying to figure this out, help.....
Old Mar 27, 2017 | 2:12 PM
kevinkpk's Avatar
You didn't post that you checked any fuse. I'd suggest check them all.
Old Mar 27, 2017 | 7:01 PM
dewayne22's Avatar
I checked all the fuses that you can visually check, don't know how to check the relays...
Old Mar 27, 2017 | 7:29 PM
kevinkpk's Avatar
There is one marked INST, that's instrument, if you have no dash at all, that one should be blown. How did you check the fuses?
Old Mar 27, 2017 | 8:57 PM
dewayne22's Avatar
I used a power probe 3 and touched all of the fuses for signal.?
Old Mar 27, 2017 | 9:48 PM
dewayne22's Avatar
Thank you so much kevinkpt, for your help, it wasn't the INST FUSE, it was the ignition B, but I didn't know how to check the long fuses with the 2 looking ***** in them as it didn't look blown, but I accidentally broke the glass off of the top trying to remove it and saw the difference, took another one and put it in and now I have power!!!! Thank you again!!!! Sorry kevinkpk...
