Forum Notice Stop in here to get the latest on CF happenings! This is also the place to get some information about site usage and the rules of the forum. Only staff and those permitted by the staff may post a new topic in this section. For permission to post something here, contact EvansBlue.
Need help on a project that is a bit out of the box.... 94 silverado v6 to inlinr 6 s
Old Jan 26, 2021 | 7:28 AM
Sharp2506's Avatar
Default Need help on a project that is a bit out of the box.... 94 silverado v6 to inlinr 6 s
I know this will sound a little unusual but I have a project that I am wanting to take on and I am wanting to put a inline 250 6 cylinder in a 1994 silverado that has a 4l60e or 700r4 and 4.3 liter already in it..... Will the inline bolt up to the transmission and what all will I need to change out for this swap.....
Old Jan 26, 2021 | 11:11 AM
oilcanhenry's Avatar
If you bolt up a 250 cubic inch motor to your 1994 Chevy, the motor might outlast the pickup. No I'm not joking at all.
The 250 is/was a ROCK SOLID motor. Of course, being a straight Inline 6 cylinder, might mean issues with interference with the fan and radiator in a 94' Chevy, but possibly not. They were common, along with the 235 Chevy mill back in the 1960's to 1970's, often bolted up to a three speed transmission, usually mounted on the steering column, or a ."3 on the Tree". Lots of half-ton Chevy and GMC pickups had them, Back then four wheel drive pickups were rare, but the old Chevy Blazer was 4x4. I-6 or V8, no V6.
If you live in a state without insane smog laws, its probably doable, but I think you'd be looking at a floor shift transmission, like a rock-crusher Muncie, or a Saginaw not an automatic, unless a three-speed or four speed non-OD, auto transmission would work for you. Think it was a TH250 and TH350 automatic. Still want a Chevy I-6, they had the 292 I-6 motor back then too
Might be an adapter for the 250 GM mill to your transmission but I dont know were it might be found. As a professional driver, I CAN tell you that almost all semi-trucks run inline 6 cyclider mills nowadays as they are inherently balanced motors, so they can run for a very long time, compared to a V-6. The 4.3 is just a 350 with two cylinders gone.
Jmagana
Oct 6, 2018 2:21 AM
trailblazer06
Feb 20, 2009 4:09 PM
QuazyQ
Jul 3, 2006 7:52 PM
