Forum Notice Stop in here to get the latest on CF happenings! This is also the place to get some information about site usage and the rules of the forum. Only staff and those permitted by the staff may post a new topic in this section. For permission to post something here, contact EvansBlue.
Need help understanding small block chevy 350
Old Feb 29, 2020 | 9:49 PM
Brathomp101's Avatar
Default Need help understanding small block chevy 350
I have a 96 gmc yukon with a 350 vortec in it that is locked up. I bought a motor out of a 94 chevy truck with only the heads and crank. I know that the 94 had a tbi (throttle body injection) and mine has vortec heads and intake. As far as I know the blocks should be the same and everything should bolt over. However during research I found that I need a special intake that cost 600 to bolt everything over. To me this makes no sense, as if the vortec heads bolt on then the vortec intake should as well? If anyone knows anything please help me out. This is my first time looking to rebuild anything, and I am by no means an expert. Thanks for letting me post. Can post pics if needed
Old Mar 1, 2020 | 3:54 AM
mtwoods1's Avatar
Default 94 Chevy 350
If I were you, I would use the entire 94 engine without the vortec heads from the 96. You won’t know the compression ratio without the help of a machine shop and that could ruin you engine.
Old Mar 1, 2020 | 8:02 AM
Little Bear's Avatar
You're fine, put on the vortec heads and vortec intake and you'll be fine. You would only need a special intake if you were trying to use vortec heads and wanted to use TBI.
Dale Manners
Jan 30, 2019 9:22 AM
bayawn
10
Jun 3, 2010 4:45 PM
pnavarroii
Mar 30, 2007 7:29 PM
