Forum Notice Stop in here to get the latest on CF happenings! This is also the place to get some information about site usage and the rules of the forum. Only staff and those permitted by the staff may post a new topic in this section. For permission to post something here, contact EvansBlue.
Thotel position sensor 1 low power and whent I thoch the brake pedale the gaz pédale
Old Jun 27, 2017 | 11:29 AM
carl lapointe's Avatar
Default Thotel position sensor 1 low power and whent I thoch the brake pedale the gaz pédale
J'ai un Avéo 2010 et un probleme avec la pédale de gaz (position sensor 1 low current)
J'utilise un scanneur innova 3030g2 pour le diagnostique.
Quand j’appuie sur la pédale du frein la pédale de gaz arrête de fonctionner.
Old Jun 27, 2017 | 2:50 PM
kevinkpk's Avatar
Throttle position sensor is a variable resistor. If you have an ohm meter, connect it on both electrical ends of the sensor, rotate the shaft 1/4, 1/2, 3/4, and full. The resistance should be linear with the shaft position, if not replace it. I'm not aware of the brake pedal, and throttle having any relationship, also check under the dash for any loose wires. Sorry I don't Francias.
