01 2500hd trans overheating need help
My truck is a gas job has the 4l80 and around town it does ok but still gets hot put a big cooler on last nite and It still has an issue the pressure line is hot and the return and cooler is cold as ice it's around 40 degrees herey pressure line is hard as a rock and return is soft after its warms and the cooler is new and has not blockage any ideas would greatly be appreciated
I've puller the return off my cooler and the fluid shot out I've also pulled the return off the trans it's self cleaned it out still same thing like if it wasn't get flow at all u would think it would heat up quickly but it don't it take a lil while to over heat I can go about 30 miles on the interstate and it slowly moves up but still will cook
glovelis
September 6th, 2015 7:55 AM
Cowetacountyoutdoorsmen
February 8th, 2015 3:03 AM
CCamp88
February 8th, 2013 11:43 AM
crcsbobby
September 14th, 2012 7:07 PM
PaulHuntzyLa
October 23rd, 2010 9:38 AM
