02 1500 express runs sluggish after restarting warm
Old Jul 29, 2017 | 4:06 PM
the Brain's Avatar
Default 02 1500 express runs sluggish after restarting warm
My van has 190K miles I’ve driven it for 10K miles and she was running fine.
Recentely the van is a little sluggish after restarting the already warm engine,
Like if I run into the store for a few minutes then restart, it will sometimes even
Cutoff if I don’t give it some extra gas to keep it alive.
This is what I’ve done
Replace w/ AC delco $35.ignition cap/rotor new spark w/ wires no joy.
Edit I only replaced 7 plugs though the wheel well, the driver side closest plug to
driver I could’nt figure out How to remove.
I’m used to driver directly after the start up if I let her warm (even when warm)
She does better is this sluggishness due to high milage?
this is a tow vehical so I would like it running at it's best.
Thanks TB
Attached Thumbnails 02 1500 express runs sluggish after restarting warm-splash1.jpg
Old Jul 30, 2017 | 9:26 AM
the Brain's Avatar
anyone w/ advice
Old Jul 31, 2017 | 8:54 PM
the Brain's Avatar
138 views zero response this place is worthless
Old Aug 1, 2017 | 8:26 PM
02silverventure's Avatar
Any codes stored?
Have you checked fuel pressure?
That's where I'd start.
Old Aug 2, 2017 | 9:26 PM
the Brain's Avatar
I'll check FP and have codes checked
apparentely the FP regulater is allmost worn out so maybe replace FP assembley to get the new FP regulater
hows this look
https://www.rockauto.com/en/moreinfo...sn=465&jsn=465
then buy here
New Carter (Made in USA) Fuel Pump Module P74779M For Chevrolet GMC 1998-2002 | eBay
