04 Silverado brake leak
Old Feb 24, 2018 | 2:31 PM
Newbie3's Avatar
Default 04 Silverado brake leak
I have a 04 silverado that has a brake leak. I have found where the leak is but not sure how to change this line out. I will try to attach a picture. It is located under the driverside door.
The leak appears to be coming from the rubber boot area that goes up into the body
Old Feb 24, 2018 | 6:54 PM
they don't run hydraulic brake lines into the vehicle only the e brake cable...which is mechanical.
the hydraulic line is steel; in the picture with a drop of brake fluid falling of it...someone has spliced into the original line as there is a union present joining the old and newer lines.
have someone step on the brake while you view the line...or use a go pro...you will see it linking out of the metal line.
