08 Suburban problem LT
Old Feb 22, 2016 | 10:52 AM
law129's Avatar
Default 08 Suburban problem LT
I have an 08 Chevy suburban 4x4 LT that I recently bought. Truck has 188K on it. Runs and drives fine. It has a weird problem I can't figure out though. It makes an electrical hum when you turn the blinkers on that increase in intensity when you accelerate. It sounds like a surge of electrical energy. It will also start sometime and then I switch the radio off and it will stop. Any help would be great. Also, The cruise button will light up but the cruise won't set.
Old Feb 23, 2016 | 1:53 PM
law129's Avatar
Default reply
Thanks for the reply. This was an auction truck so there is no telling what the problem is. the only time it really does it is if the radio is on with the blinkers. It seems like the more power drawn from the battery the more it does it, but if you are just driving with no radio, it usually doesn't happen. I am not sure on the cruise. I have read there is a switch behind the gas petal that goes bad on them. Haven't checked that yet. Haven't checked the fuse either.
Old Feb 24, 2016 | 7:55 AM
cleveland63b's Avatar
brake pedal not gas pedal, the brake switch is a very common problem you could try lifting up on the brake pedal slightly and seeing if cruise will work and if it does your switch is most likely toast.
Is it the stock radio?
Old Feb 24, 2016 | 8:23 AM
law129's Avatar
Yes, brake not gas. It has the factory stereo that works fine. You think the switch in the pedal or the multifunction switch?
