10.2 to the 1/8 wanna go faster
Old Aug 28, 2025 | 11:19 PM
Poptart123358's Avatar
Default 10.2 to the 1/8 wanna go faster
so i have 1975 Camaro all the specs are 350sbc 2 bolt main, th350, 10 bolt with 3.73 gears, posi trac. I made a pass at the drag strip for the first time and i ran 10.2 this was 1/8 mile so it was very very slow, my rt was 0.42 which is also very very slow. i really just want some opinions from other people that have messed with this type of stuff before. should i pull the 350 out and build it or swap for a big block, i think the small block would be better for my budget but i haven't looked into fulling build a big block yet either. if i went the sbc route should i do a stroker kit or nitrous or both, if i did nitrous what shot size? i also wanna swap the transmission, on summit there is a th400 that already has a trans brake its $2600. what kind of torque converter should i use, what is a good stall? should i swap to a ford 9 inch or a 12 bolt, what kind of gears should i use? my goal is 7.9 to the 1/8, for the amount of money i plan on spending is this realistic goal? my budget is $5000 for the engine and $6000 for everything else.
Old Aug 30, 2025 | 1:08 AM
Robby17's Avatar
For an 7.9 goal, your budget is tight but doable if you're smart. Stick with the small block for cost. A stout 383 stroker build with good heads and a solid cam will get you there. A 150-200hp nitrous shot would help a lot.
For the trans, a built TH350 or 400 with a brake is good. Get a converter matched to your cam; expect a 3500-4500 stall. Your 10-bolt with 3.73s will break with more power. A Ford 9-inch or 12-bolt with 4.10 or 4.56 gears is the right move.
Focus on the engine and rear first. Your goal is realistic with that budget if you prioritize.
BoogerHog
Dec 25, 2016 11:32 PM
ITSBACK
Apr 17, 2010 6:41 PM
badwrench
Sep 9, 2009 8:47 PM
