1983 g20 van
Old Oct 22, 2006 | 4:30 PM
dick2256's Avatar
Default 1983 g20 van
does anyone know where I can get the ignition wiring schematic for this van? Need to know where to locate the fusable link in the ignition section.
It will start after running a wire from positive post on battery to any wire in the ignition circuitalso up under dash by the emergency brake pull off there is a red box going to the ignition through a several wire plug and it has a burned resistor. That box has a board inside that is loaded with diodes, resistors,transitors and several ics (intregated ciecuits)
Dick
Old Oct 24, 2006 | 9:52 AM
dick2256's Avatar
Default RE: 1983 g20 van
ORIGINAL: dick2256
Dick
found my problem to be the fusible link coming off the starter put in a new link and all is fine again.
dick
Old Oct 24, 2006 | 9:54 AM
dick2256's Avatar
ORIGINAL: dick2256
ORIGINAL: dick2256
Dick
dick
that little red box with the burnt resistor was the cruise control module.
Dick
Sabreman
Dec 21, 2016 11:56 AM
Nash
Oct 3, 2015 8:15 AM
InMy83Chevy
Sep 23, 2013 6:42 PM
corellian corvette
Nov 19, 2012 12:08 AM
dick2256
Oct 19, 2006 12:31 PM
