1992 S-10 PU Stalling
Old Apr 26, 2009 | 3:32 PM
rio9760's Avatar
Default 1992 S-10 PU Stalling
The car needs a prime of gas to start it, once it starts the eng will run for a few seconds by itself then stalls, feather it and it starves and dies. Did a complete tuneup NG. I replaced the MAP sensor NG. Disconnected the alt 2wire plug and it ran fine? Please help in any way possible. TU
Old Apr 26, 2009 | 11:40 PM
Mike Sigmond's Avatar
ROTM Coordinator
Fuel filter, Fuel Pump possibly, vacuum leak, gaskets, ignition, could be alot of things?
Old Apr 27, 2009 | 5:43 PM
rio9760's Avatar
Default Stalling
Thanks Mike
I was going to try and get a fuel pres reading over the weekend, the only thing throwing me off is the alternator thing where it stays running when unplugged?
Old Apr 27, 2009 | 5:54 PM
ROTM Coordinator
If you unplugged your alternator the engine will just begin using your battery, Sounds like you have a bad alternator browning out your electrical system. Have it tested for free at a local parts store.
Old May 9, 2009 | 10:29 PM
rio9760's Avatar
Hi
Finally got some good weather to work on the truck. Replaced the fuel pump in the tank and its running fine. Thanks all
Philzell
Jul 11, 2011 10:47 PM
excesss
Feb 22, 2006 9:15 PM
TurboDSM86
Dec 22, 2005 12:42 AM
sejs
Aug 19, 2005 11:55 PM
