1994 chevy g20 - close loop runs rich
Old Nov 19, 2019 | 7:11 PM
  #11
IRON MIKIE's Avatar
I ordered extra ground straps to be installed this week. :-)
Old Nov 20, 2019 | 3:40 PM
  #12
IRON MIKIE's Avatar
well, the van battery voltage read under 12 volts this morning. So I purchased a new battery and the van runs much better.
Maybe most of the low voltage ghosts are back in the closet. :-)
More test driving to come.
Old Nov 21, 2019 | 11:38 AM
  #13
IRON MIKIE's Avatar
OK, I finally have opened the White Box and have ALDL live telemetry data at runtime now.
The 1ST PASS on data capture confirms there is low voltage on the coolant temperature sensor. And there are 4 malfunction codes present. Yet there was no engine light present at this time.
MALFUNCTION CODES
Old Nov 21, 2019 | 11:57 AM
  #14
IRON MIKIE's Avatar
OBD1 ERROR CODE 42 CHECK
https://www.turboimagehost.com/p/233...gnos1.jpg.html
Old Nov 21, 2019 | 12:19 PM
  #15
IRON MIKIE's Avatar
4 LOW VOLTAGE ISSUES. It must be a grounding issue? Somewhere? My new ground straps arrived today. Time to wrench them on the van.
Old Nov 21, 2019 | 2:12 PM
  #16
IRON MIKIE's Avatar
WOW BIG LESSON LEARNED
DO THE CHEAPEST FIX FIRST!!!!!
Malfunction code are gone.
I cleaned every ground connection to the engine I could find.
I inspected, I tested with a voltmeter, .... and the resolution to the van's low voltage issue was poor ground contacts. All the black box ground tests checked out good. A big false positive in this challenging project.
These older ECM vehicles are very sensitive to poor grounds. I have my van on the ALDL scanner ... going for a test drive.
I shared my pain with you so hopefully, you can avoid it.
Cheers!
Mike
Old Nov 21, 2019 | 3:08 PM
  #17
IRON MIKIE's Avatar
POST MODEM:
My van is running great now.
Poor ground to the motor was the problem.
Time vs Money
Define the Symptoms
Identify the potential cause(s) of those symptoms
Get the right tool for the job
Measure the data points of the potential cause(s)
Do the cheapest repairs first.
Clean all ground points even if they test good and look good visually.
Cheers,
Mike
Watch Healthy Chevy 5.7L
Old Nov 23, 2019 | 3:52 PM
  #18
IRON MIKIE's Avatar
GHOSTs BUSTED!!! - NO MORE LOW VOLTAGES Van issue was ROOT CAUSE WAS RUST RELATED ON GROUND CABLES TO ENGINE.
as RUST RELATED.
mmanna
Aug 8, 2019 9:12 AM
BIGTEXTRUCKER
Astro
Oct 24, 2018 10:32 PM
AstroBoy94
May 20, 2017 8:41 PM
alphons bwart
Jul 16, 2014 7:31 AM
Shamus
Sep 10, 2010 1:12 PM
