1994 silverado..no forward gears after rebuild only reverse...
Old Jun 6, 2019 | 6:16 PM
Xyang's Avatar
Default 1994 silverado..no forward gears after rebuild only reverse...
Fluid is full, new wiring harness, all new electronics, new everything inside the transmission. I only have reverse no forward gear no matter where i put the shifter lever....this is the second time i took it apart and third install all 3 same results....
Old Jun 8, 2019 | 2:33 PM
Beau Oszman's Avatar
Take apart again, inspect again, reassemble slowly again. Only mistake I've seen made that might compare, gasket was upside down.
