1995 K 2500 5.7 TBI no spark
Old Nov 3, 2024 | 4:02 PM
KDaniels's Avatar
Default 1995 K 2500 5.7 TBI no spark
I reinstalled the engine, 1995 K2500 5.7 TBI, after rebuild and had no spark. in the process of trying to determine the issue I fried the coil. replaced coil still no go. replaced distributer and another coil. still nothing. I have 12v. to both pink wires on coil. good ground block to frame, frame to chassis, chassis to block. I connected a LED to the white signal wire on the coil from the distributer and when I apply voltage the ignition energizes with the key off, fuel pump starts, etc. don't know if this is to be expected. should there be a ground from the controller to the distributer? or does this occur when the signal is sent from the controller? i do not have continuity on any of the kind going to the distributer.
THase89
1988 - 1998 (GMT400)
Apr 11, 2022 9:37 PM
bakerb
Jan 5, 2022 11:57 PM
Chevygirl93
16
Sep 7, 2020 4:57 AM
77south
May 9, 2018 4:41 PM
captainhooky
Jul 22, 2012 10:54 AM
