1998 K1500 5.7 misfire issues
Old Apr 29, 2010 | 1:47 PM
thelandry1's Avatar
Default 1998 K1500 5.7 misfire issues
ok I have a 1998 K1500 5.7 that keeps throwing a #5 misfire code. I've changed the Cap Rotor Wires and Plugs....nothing changed....It has a consistant misfire at idle and when it's in overdrive under load like going over an over pass or up a hill on the interstate....I've checked the plug and it's white with a little build up............It started doing this after I changed the fuel filter ...before that the check eng light never came on.. it idled fine and accelerated fine....What's the problem?
Old Apr 29, 2010 | 6:30 PM
desrtrat's Avatar
you may have a clog/dirty injector. check compression on that cylinder also
good luck
codeman061988
May 31, 2020 8:07 PM
smithers
Apr 28, 2015 3:54 AM
smithers
Apr 22, 2015 4:11 PM
codeman061988
Oct 31, 2014 12:36 PM
Travis_LeVan
Jan 16, 2014 6:10 PM
