1998 Z71 misfire and losing coolant
Old Apr 5, 2013 | 11:35 PM
Keck15's Avatar
Default 1998 Z71 misfire and losing coolant
I have a 1998 k1500 silverado 4wd 5.7L that has started to miss and lose coolant but is not leaking. It seems to really only miss while idling. A mechanic friend has told me that it's something to do with the intake. I'm sure it's burning coolant. The truck has 215k miles on it and is just a junker but I'm gettin tired of filling the coolant about once a week. If anyone has an idea on fixing it please help.
Old Apr 6, 2013 | 5:55 AM
If you are lucky it is only an intake gasket. Check to see if there is oil in the coolant or coolant in the oil. If there is coolant in the oil then you are going to create more serious problems by driving it. Pull the intake manifold and check the gaskets. You should probably do a valve job or even a ring job with that many miles on it.
Greenhead
Nov 3, 2014 11:37 PM
dmdillon
Nov 3, 2009 11:19 PM
Dirtbike768
Mar 25, 2009 10:51 AM
flash12
Dec 23, 2008 10:13 AM
Eric Kropp
Sep 17, 2008 8:20 AM
